pc to xbox connection help
Discussion in 'Xbox Forums' started by duffduff, May 14, 2004.
  1. duffduff
    duffduff
    Hello again,
    My mate now has btyahoo via usb modem into his PC. The xbox sits about 1 metre away and is working and connected to his tv.
    The only problem now is that we cant seem to connect to xbox live, i believe i am using all the right cables etc but is there settings that need to be changed on the pc or the settings menu?
    Any help would be much appreciated as ip's and dns things are a bit above my skill level.
    :thumbsup:
    many thanks in advance
  2. Pooon
    Pooon
    Dec 26, 2002
    7,372
    Canterbury, Kent
    +968
    there is a 'internet connection sharing' connection guide at www.xbox.com that lots of people have found helpfull. It keeps it simple from what ive seen and doesn't waffle on about ports and dns settings etc
