PC to TV
Discussion in 'Desktop & Laptop Computers Forum' started by shanklyforever, Oct 21, 2005.
  1. shanklyforever
    shanklyforever
    First off please forgive me that I am a complete computer novice...
    The situation I have got is that my room is too small to accomodate my TV, games consoles and PC, which frankly I only use occasionally to check emails/msgs etc.
    I'm wondering if there is a way I can connect my PC to my Philips TV, thus using the TV as a monitor. I can then get rid of my proper monitor and save some space.
    I've seen this item:
    http://www.tvcables.co.uk/cgi-bin/tvcables/PCTOTV3.html
    Would this be of use?
  2. OneEleven
    OneEleven
    That's suitable if your video card has s-Video out.
    If you don't have s-Video out, then there's a product I used a while back called the Avermedia Averkey, which plugs into your vda socket and provides composite, s-Video, and component outputs. It gave OK if not breathtaking results.
    It migth also be worth checking the VGA to RGB SCART thread on hear also
