PC to Toshiba 32wl48 via HDMI : Has _anyone_ been successful?
Discussion in 'LCD & LED LCD TVs Forum' started by WonkyEwok, Dec 26, 2004.
Tags:
  1. WonkyEwok
    WonkyEwok
    Dec 12, 2004
    464
    28
    +62
    I'm thinking really strongly of buying the toshiba 32wl48, as I'd prefer HDMI to DVI-with-HDCP (ie a Sharp) if possible. But....
    Has anyone managed to get a pc to properly fill the screen over an HDMI connection? I'm guessing that HDMI will give the clearest display, and should allow 1 computer pixel = 1 screen pixel, even if some get chopped off at each side.
    I don't remember finding any success stories in the various threads on this; please forgive me if I've missed something in my searching.
    Thanks :smashin:
  2. jgrg
    jgrg
    Oct 19, 2004
    556
    28
    Cambridge
    +36
    I haven't read that anyone has been successful either.
    The HDMI connection may not necessarily support 1:1 pixel mapping from a computer input. It will, I'm sure, support 1280x720 at 50Hz and 60Hz (since this is a standarad HDTV resolution), but the screen would scale this up to 1366x768 (the native resolution of the screen), which isn't 1:2 and would be bad for computer text.
    James
