PC to Sony 32S2030 (D-Sub)
Discussion in 'Sony TVs Forum' started by sixarm, Apr 26, 2007.
  1. sixarm
    sixarm
    Hello there,
    Has anyone connected their PC to this Sony model?
    I've currently got mine connected via DVI to the HDMI port with fantastic results. I'm just about to get Sky HD, and due to the fact that the Sony has a single HDMI input, I wondered how it would perform using the D-Sub input.
    I take it I would be able to run it in 1360 x 720 as I can using my current setup?
    Any advantages/disadvantages to using the D-Sub input?
    Thanks in advance.
  2. BillyHey
    BillyHey
    Feb 14, 2007
    28
    3
    Linlithgow
    I've had mine connected to my 32S2530 using VGA and it's fine. TBH I've never noticed the difference between VGA and DVI for PC use, it might make a difference if you're doing video editing or photoshop but otherwise...
    I've currently got my xbox 360 connected to VGA as it upscales SD DVD over that (but doesn't on component).
