PC to PV500
Discussion in 'Plasma TVs Forum' started by DWF, Mar 9, 2006.
  1. DWF
    DWF
    May 22, 2005
    75
    11
  2. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Right, I assume you are connecting to a DVI output of the PC to VGA on the plasma? In which case it's easy. There is no signal because there are 2 standards for DVI cable, and you have the wrong one. DVI-D is digital only, you need DVI-I. The D class is missing some vital pins, simple innit?
  3. pointyone
    pointyone
    Dec 3, 2005
    812
    +22
    maw i have a radeon 9800xt gfx card that has dvi -i out i conected to my plasma via dvi-d to hdmi(lead) would i have noticed any difference
    also is there any advantage of going dvi to vga rahter than vga to vga
  4. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    DVI-D to HDMI is fine, digital all the way. VGA-VGA is fine if you have a VGA out on the card. Many cards these days have only DVI-I, so a DVI-I lead and a converter at the plasma end is OK, or put the converter on the PC end and use a VGA lead, makes no difference.
  5. DWF
    DWF
    May 22, 2005
    75
    11
    Thank you MAW.
