pc to projector
johnkay
Joined
Sep 12, 2002
Messages
112
Reaction score
Points
70
Age
67
Location
west midlands
Hi can someone let me know how to connect a pc to a projector for a meeting, I know normally a laptop is used but would an ordinary pc be able to do instead, do I take the monitor off and plug that to the projector do I need special cable etc.
Hi johnkay,
You can use the same VGA cable as you would with a laptop. As you say, simply remove the cable from the computer monitor end and plug it into the RGB input on the projector.
Remember that you will only be able to see the image through the projector if you do this, whereas laptops have the ability of sending the image to the laptop screen as well as to a projector.
Good luck!
MRW
StormAudio ISR Fusion 20 AV Receiver - review coming soon #HomeCinema #Amplifier #VideoShort
Back
