PC to Projector not lining pixel to pixel
Discussion in 'Projectors, Screens & Video Processors' started by Tommy Angelo, Jul 2, 2004.
  1. Tommy Angelo
    Tommy Angelo
    I have a Panasonic AE500 projector and when I plug it into the PC and set the resolution to 1280x720 (the AE500 LCD resolution) it doesnt match the pixels up so the screen is within the LCD instead of using every pixel, can this be fixed somehow? Would using a DVI cable fix it?
    Thanks in advance
    Andrew
  2. petrolhead
    petrolhead
    Mar 29, 2002
    4,863
    87
    Newcastle
    +123
