PC to process stereo into DD5.1
Discussion in 'Desktop & Laptop Computers Forum' started by NaTT, Sep 9, 2004.
  1. NaTT
    NaTT
    May 27, 2003
    1,123
    Abbots Langley
    +77
    my amp doesn't do Prologic II, so I was wondering if it was possible to capture sound from a stereo TV source and process it into surround sound (that's a bit better than normal prologic) and pass it out over spdif flagged as DD or DTS (so my amp can pick it up)?
  2. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    Motherboards using the nForce2 chipset have on-board Dolby Digital encoding which can do some sort of multi-channel synthesis, not sure if Audigy cards et. al can do that. Maybe there's a software-based DSP but I don't know of one off-hand.
  3. drummerjohn
    drummerjohn
    Sep 2, 2001
    2,494
    South Derbyshire
    +203
    Yeah - motherboards using the Nforce2 MCP-T chipset will do this. Some Nforce2 motherboards have the have the MCP - these wont do it. If the specs say it has MCP-T or Sounstorm then you wont go wrong.
