PC to plasma
Discussion in 'Plasma TVs Forum' started by TheBigApple, Apr 24, 2003.
  1. TheBigApple
    TheBigApple
    Dec 10, 2002
    665
    In my cage
    +13
    Can anyone tell me how to connect a desktop pc to a Pioneer 433HDE. i.e do I use the monitor output on the pc, what type of cable do I need and where can you get them.
    Ta
  2. Dutch
    Dutch
    Dec 5, 2002
    2,601
    2
    5
    North Yorkshire
    +284
    Hi mb73,
    Yes, use the monitor output from your pc. You need a VGA cable - try www.lindy.com/uk/ for good quality screened ones with a 25 year warranty!
    Steve
  3. TheBigApple
    TheBigApple
    Dec 10, 2002
    665
    In my cage
    +13
    Thanks for the info.
    I now have my pc connected, however I can only display the screen in 4:3 or 16:9.
    I believe there is a setting to change windows xp to widescreen but can't seem to do this.
    Any ideas.
    Ta
  4. Dutch
    Dutch
    Dec 5, 2002
    2,601
    2
    5
    North Yorkshire
    +284
    To change your display settings, right click on the desktop>properties>settings. Good luck!
    Steve
  5. symanski
    symanski
    Jun 20, 2002
    874
    Scotland
    +8
    There's another application called Power Strip that may be of interest to you. It allows you to set the output resoltion of your PC to match that of the Plasma. Search the net or this forum for where to download this application (it's shareware).
    All the best,
    Dr John Sim.
