PC to Plasma - what resolution should I be using?
Discussion in 'Desktop & Laptop Computers Forum' started by wyerd, Dec 20, 2004.
  1. wyerd
    wyerd
    Dec 29, 2000
    761
    28
    Upstate New York. USA
    +27
    I took delivery of my new Panny plasma - TH-42PDH7 - last week, but I'm not sure what resolution I should be selecting for the graphics card - 9600 XT Ultimate. I've connected the PC to the display via VGA at the moment as there's a wait for HDMI boards. The display's native resolution is 1024x768 and accepts the following resolutions :-
    750 (720)/60p 45.00 60.00
    750 (720)/50p 37.50 50.00
    1125 (1080)/60i 33.75 60.00
    1125 (1080)/50i 28.13 50.00
    1125 (1080)/24sF 27.00 47.92
    1125 (1080)/30p 33.75 30.00
    1125 (1080)/25p 28.13 25.00
    1125 (1080)/24p 27.00 24.00
    1250 (1080)/50i 31.25 50.00
    640 x 400 @70Hz 31.46 70.07
    640 x 480 @60Hz 31.47 59.94
    640 x 480 @72Hz 37.86 72.81
    640 x 480 @75Hz 37.50 75.00
    640 x 480 @85Hz 43.27 85.01
    852 x 480 @60Hz 31.47 59.94
    800 x 600 @56Hz 35.16 56.25
    800 x 600 @60Hz 37.88 60.32
    800 x 600 @72Hz 48.08 72.19
    800 x 600 @75Hz 46.88 75.00
    800 x 600 @85Hz 53.67 85.06
    1024 x 768 @60Hz 48.36 60.00
    1024 x 768 @70Hz 56.48 70.07
    1024 x 768 @75Hz 60.02 75.03
    1024 x 768 @85Hz 68.68 85.00
    1152 x 864 @75Hz 67.50 75.00
    1280 x 960 @60Hz 60.00 60.00
    1280 x 960 @85Hz 85.94 85.00
    1280 x 1024 @60Hz 63.98 60.02
    1280 x 1024 @75Hz 79.98 75.03
    1280 x 1024 @85Hz 91.15 85.02
    1600 x 1200 @60Hz 75.00 60.00
    1600 x 1200 @65Hz 81.25 65.00
    1066 x 600 @60Hz 37.88 60.32
    1366 x 768 @60Hz 48.36 60.00
    Mac 13˝ (640 x 480) 35.00 66.67
    Mac 16˝ (832 x 624) 49.72 74.54
    Mac 21˝ (1152 x 870) 68.68 75.06
    I use the PC for DVD & Nebula DigiTV
    Thanks,
    David.
  2. whats_this
    whats_this
    Dec 26, 2003
    504
    +11
    you want to output at the native resolution of your display to achieve 1:1 pixel mapping. This means all the scaling is done by the computer which is more powerful than the displays scaling.
  3. DrPepper
    DrPepper
    Oct 2, 2001
    3,317
    Barking Essex
    +263
  4. wyerd
    wyerd
    Dec 29, 2000
    761
    28
    +27
    So using powerstrip, I would need the timing parameters for 1024 x 768 @60Hz?
  5. cwick
    cwick
    Feb 4, 2002
    2,231
    Reading
    +95
    You'll only need powerstrip if your graphics driver doesn't support native resolution out of the box (or not at the refresh you want). You should have 1024x768@60Hz available as a standard resolution, which should work just fine.
  6. wyerd
    wyerd
    Dec 29, 2000
    761
    28
    +27
    The default plug & play monitor doesn't support it. Which one should I be using?
  7. CodeThief
    CodeThief
    May 25, 2002
    663
    UK
    +5
    Eh???
    1024x768 is VERY VERY common, I'd be very surprised if your monitor driver didn't support it?
    Dave
  8. wyerd
    wyerd
    Dec 29, 2000
    761
    28
    +27
    I'm at work at the moment. I'll check when I get home later. I'm running the latest ATI cat drivers 4.12
  9. wyerd
    wyerd
    Dec 29, 2000
    761
    28
    +27
    OK. Set the resolution to 1024x768.......now I'm really confused 'cos the plasma's a widescreen device and 1024x768 is 4:3. The Desktop is now streatched in 16:9 unless I set it to 4:3, then I get black bars on the side. Is this what I should expect?
  10. cwick
    cwick
    Feb 4, 2002
    2,231
    Reading
    +95
    Yup, that's how it should be. The pixels aren't square.
    Which means you need DVD playback software (etc) that understands the odd screen ratio you're using ... e.g. TheatreTek (that's the only one I've tried, I'm sure there are others).
    DigiTv has an option on it for this - I think it's the anamorphic one in the general or display settings.
    Cheers, Carl.
  11. wyerd
    wyerd
    Dec 29, 2000
    761
    28
    +27
    I'm using ZoomPlayer for DVD playback. Just now got to find a suitable theme for Meedio.
