pc to plasma question..please
Discussion in 'Plasma TVs' started by tabs, May 6, 2005.
  1. tabs
    tabs
    Apr 3, 2005
    1,919
    warks
    +130
    ive just tried putting my pc through the plasma (LG) and the picture was superb, i used the standard lead that connects the pc to the monitor, (not sure of the proper term for it RGB ? SVGA ?)
    what i was wondering is...is there a splitter avaliable to buy so that i can use either the plasma or pc monitor without swapping leads everytime from the back of the pc, thanks folks
  2. Liam @ Prog AV
    Liam @ Prog AV
    Well-known Member AVForums Sponsor
    Oct 18, 2002
    8,498
    Kent
    +827
    Yep, VGA distribution amp (DA) required - Keene Electronics do one I'm sure. Alternatively second graphics card to enable doing one thing on the plasma and another on your monitor....
  3. tabs
    tabs
    Apr 3, 2005
    1,919
    warks
    +130
    nice one liam, only though it would be about a tenner, lol :D
    also, whats the technical term for the audio lead from the pc to the audio socket next to the RGB socket ? fanks
  4. lisag
    lisag
    Jul 14, 2004
    5,993
    Essex
    +398
    What graphics card do you have in your pc? Many allow you to operate dual monitors off the same card.
  5. Liam @ Prog AV
    Liam @ Prog AV
    Oct 18, 2002
    8,498
    Kent
    +827
    3.5mm minijack at the PC end. The plasma will either have another minijack, or have dual RCA sockets.
  6. tabs
    tabs
    Apr 3, 2005
    1,919
    warks
    +130
    i have an MSI fx5800, it has a DVI output, but i tried going down the DVI route but had nothing but grief, whereas the standard VGA on the graphics card to the VGA socket on the plasma was superb from the word go..its all dutch to me mate :confused:
  7. lisag
    lisag
    Jul 14, 2004
    5,993
    Essex
    +398
    Well you are in luck, looks like that graphics card has dual RAMDACs which means it can run two displays at the same time. You need to use the VGA for one display and the DVI for another, but you should have got a DVI to VGA adaptor with the card so you do, in essence, use two VGA outputs. Then use the Nvidia drivers to configure the displays.
    lisa
  8. Dan L
    Dan L
    Feb 7, 2005
    2,201
    Wotton-under-Edge
    +110
    Aye, use the NView options to set the displays in "Clone" mode.
    Like Lisa says, you'll need a DVI->VGA converter - these don't always come supplied with the card, so if you don't have one you can get one at your local PC World for about fifteen quid.
