PC to Plasma problem!!!!!
Discussion in 'Plasma TVs Forum' started by lofty29, Oct 2, 2005.
  1. lofty29
    lofty29
    Sep 29, 2005
    202
    +3
    After much fiddling, I managed to get my plasma to recieve a pc signal through the s-video lead, but I can only get it in black and white.
    How do I get it to be in colour? :lease:
    cheers
    Lofty :)
  2. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    What plasma, is there a choice in the graphics card for composite/s-video, what leads are you using. Composite through an s-video connection is B/W, or s-video into a composite or RGB scart socket is B/W, so could be either of these.
  3. lofty29
    lofty29
    Sep 29, 2005
    202
    +3
    I have the Pioneer PDP435FDE, and my cable I use from the G-card is all black, and I have an s-video connector on the card, then the other end goes into the yellow hole on the back of the media reciever.
    Any clues!!!!!!!!!!
    Lofty :)
  4. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    There you go then, you have an s-video to composite lead, you are feeding s-vid into a composite socket, no colour. Wrong lead, or wrong software setup.
  5. lofty29
    lofty29
    Sep 29, 2005
    202
    +3
    Thanks mate :thumbsup: , stupid Lofty :eek:
    What sort of lead do I need then?
    Can you get a lead with 2 s-video ends?
    Lofty ;)
  6. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    yep, that would be an s-video cable :)
