PC to PJ and Monitor!! Is this graphics card ok?
Discussion in 'Desktop & Laptop Computers Forum' started by MrCoopz, Aug 9, 2002.
  1. MrCoopz
    MrCoopz
    Jun 28, 2002
    1,107
    63
    +115
    Hello im buying a new graphics card for connectong both PJ and monitor without a switchbox, Im looking at this one
    V8420 /TD : GeForce4 Ti VGA, 128M DDR Memory, VGA-out, TV-out, DVI-I
    Graphics Engine: NVIDIA® GeForce 4 Ti 4200 GPU
    Video Memory: 128MB DDR Video Memory
    OpenGL: Fully 1.2 Compliant OpenGL Support
    Vertical refresh rate: 70-240 Hz
    Max. Resolution: 2048 x 1536 x 85Hz
    Bus Standard: AGP 4X / 2X
    VGA outport: Standard 15-pin D-sub
    TV-out port (adaptor bundled): S-VHS & Composite
    Digital Flat Panel output: DVI-I
    would it be ok for connectong both PJ and monitor without a switchbox and if so how would i connect both my Pj and Monitor at the same time.
    would i need to buy anything else??
  2. Kramer
    Kramer
    Just replied to your question here .
    That's all you need.
    Gainwards are also suitable, @ ~£125.
