PC to panny
Discussion in 'Projectors, Screens & Video Processors' started by wynouk, May 2, 2002.
  1. wynouk
    wynouk
    I've just bought a 12 metre length of 20 core screened cable from maplins with 2- RGB 15 pin male plugs with the intention of connecting up my panny to my PC.
    the only trouble is that my PC graphic's card which is a elsa gladiac 511 has only 1 female 15 pin rgb socket in the back of it so has anyone got any idea's on the best options on getting both my pc monitor and panny working at the same time, is there some sort of adaptor i can buy or what????
    thanks.
  2. Dubbing Mixer
    Dubbing Mixer
    Jan 27, 2002
    643
    By, and sometimes in, the sea
  3. Kramer
    Kramer
    Upgrade your graphics card to a Radeon 7500. These have twin VGA output (one is DVI, but an adaptor is supplied).
    You can set up hotkeys to switch between displays, eg. projector or monitor.
    Get yourself a Pronto & IrMan & you have full remote control switching, & no cables to mess about with ;)
