PC to LCD using VGA or COMP?
Discussion in 'LCD & LED LCD TVs Forum' started by hamd01, Jun 17, 2005.
Tags:
  1. hamd01
    hamd01
    Mar 21, 2005
    959
    46
    Cumbria
    +145
    When my Sammy 32" arrives from Empire, Id like to try some PC games on it at 1280x1024. Would I get good results using a VGA cable?
    I dont have a very high spec PC, but I have a decent graphics card but it doesnt have component or DVI out.
    FIFA is about the only game I play, and it looks much better than XBox or PS2 on my PC IMHO. Will I get the benefit by using a VGA cable from the PC to the screen, or should I buy a new graphics card with a different type of output?
    :lease:
  2. sandstheman
    sandstheman
    Jan 6, 2005
    545
    28
    +49
    VGA or DVI would be the best way to connect your PC to the screen, but that depends on what connections the Samsung screen comes with. I would stick to one of those 2 and you won't go wrong.
  3. hamd01
    hamd01
    Mar 21, 2005
    959
    46
    Cumbria
    +145
    The Samsung has VGA, thats a big help thanks!
