PC to LCD TV
Discussion in 'LCD & LED LCD TVs Forum' started by forever_red, Sep 13, 2007.
Tags:
  1. forever_red
    forever_red
    Hello Guys
    Im having a bit of trouble on setting up my pc to my LCD tv.
    What i've tried so far, is connected my graphics card from my pc to the tv by using a dvi-hdmi adapter and then hdmi to hdmi cable straight to my tv.
    All im getting is a blank screen, Do i need to activate a screen, or change any resolution settings, or output mode on my pc in order for it to pickup. I have a 32" Samsung which i belive goes up 1360x768
    Im not that technically clued up so any help would be well appreciated.
    Thanks,
  2. TechieSarah
    TechieSarah
    Jan 6, 2007
    1,787
    Midlands
    +218
    I run my PC through a Phillips 28" LCD TV
    I run a DVI connector from the back of the PC to the input of the screen.
    I have to select input as PC-D on the remote, which is PC-Digital teh other option is PC-A which i presume is PC-Anaologue.
    I had to change no settings on my PC and can run at a range of resolutions.
    If your currently got a cable between PC and TV check the remote for input settings, i.e. source and amke sure its Digital or DVI
  3. Mooky55
    Mooky55
    Sep 28, 2006
    763
    London
    +30
    Yeah assuming that you have changed the Source or Input setting to HDMI to correspond with the input you are using, from your text it would seem HDMI.. I would try Rebooting the PC.
    At taht point, if it still does not work, there could be something wrong with your cable or converter, try using a DVI cable to your DVI slot on your tv or if you only have vga, then a dvi to vga converter and see if you get a signal by that input (obvioosuly changing the source/input each time to the one your are using).
  4. forever_red
    forever_red
    hi,
    For some reason on my tv using the source buttons i can only scroll through ext1,ext2,av and digital tv, the manual says s-video, component, pc and hdmi should be there too, but i cant see any.
    I have also tried using a straight vga connection pc to tv but again nothing came up.
