PC to LCD TV Connections
Discussion in 'LCD & LED LCD TVs Forum' started by Alexeroth, Oct 22, 2004.
Tags:
  1. Alexeroth
    Alexeroth
    I am considering buying an LCD TV which I also want to connect to my laptop.
    My laptop only has a DSUB VGA output. Does this mean that I must buy a TV with a DSUB input or is there some way that I can use DVI on a TV.
    My laptop is 1280 by 800 native resolution, but also supports other native . Do the LCD TVs have native resolutions and will the picture only look ok if one of my laptops resolutions match the tv's native resolution?
