PC to LCD question - Which cable
I don't mean to rain on your parade but the VGA to component cable will only work if your card supports this, most do NOT
S-video should be ok for watching films etc, but for the web and documents it may be unreadable.
Do your TV's have HDMI? As a cheap DVI card can be easy used over DVI>HDMI.
Best Regards
Chris
$lim$hady
Best Regards
Chris
Thanks Lindy Tech, I will try the Svideo first, if PQ is fine i will leave it otherwise get the DVI card you suggested.
so i guess i will need a svideo cable and a sound cable (3.5mm) too?
Yes, if your card has S-video out, all you need is an S-video cable and a 3.5mm cable. Sometimes the TV will want 2x phono style inputs however, so you would need a 3.5mm to 2x Phono.
We sell all these cables below, give me a shout if you cannot find what you need.
S-video cables
Audio cables
Chris
$lim$hady
Thanks again,
What would be the best option for best PQ? (hdmi/DVi NA)
Svideo to Scart or Svideo to Svideo.
It will be used on a 50" plasma....
MarkTaylor
S-video to Scart or S-video to S-video.
S-Video to SCART or S-Video to S-Video are both S-VIdeo so no difference.
SCART is just a connection type.
Do check that your plasma supports S-Video over SCART though as not all do.
Main advantage of going that route is you can get a cable that will take your S-Video and sound sources and combine them into the SCART connector.
Do make sure you get S-Video to SCART not SCART to S-Video as they are not the same.
Joe Fernand
AVForums Sponsor
Hello $lim$hady
First question has to be WHY?
Unless its the only option for viewing the Source material you want to view using a PC connected via S-Video makes no real sense if you have a large format high resolution display.
What are the Displays you want to view the PC on?
Joe
PS Are you the real one?
$lim$hady
Hello $lim$hady
Joe
Yeah, this would be the only option for me, i have lots of AVI on my laptop so would like to view them on the plasma, the laptop is a BIG Sony (don’t know the displays). S-Video is the only option unfortunately.
I am not the real Slim but more of the Stan...:devil:
S-Video to SCART or S-Video to S-Video are both S-Video so no difference.
Joe Fernand
AVForums Sponsor
Hello $lim$hady (or is it Stan...)
A link to the Plasma Display Manual or Tech Spec would be good - someone may be able to suggest something better than S-Video.
Joe
