R
rmoase
Hello all, wondering if anyone out here has connected a pc to an HDTV?
i read that you need a program called PowerStrip, but i also came across this vga-->component adapter (http://www.ati.com/support/connectors/componentvideo/cablecomponentvideoadapter.html)
As you can see this adapter has jumpers on it to set depending on the compatibility of the HDTV. Does this mean that if you shut off pc, then connect adapter, then tv , then set jumper (to say 1080i) then turn pc on, it will be at an optimum resolution and refresh rate the tv can accept?
Any help appreciated. Thank You
