PC to DVD-RAM - How?
Discussion in 'Blu-ray & DVD Players & Recorders' started by crawf1982, Jan 27, 2005.
  1. crawf1982
    crawf1982
    Jun 21, 2002
    183
    East Midlands, UK
    +7
    I have an LG multi format dvd burner (4040 model) in my PC. I used it to back up a DVD-RAM disc recorded on a standalone DVD recorder to my HDD - I just copied the whole DVD_RTAV folder. How can I now transfer the information back onto a blank DVD-RAM disc. Can I do it using Nero? If so what settings do I need to use?
    Many thanks,
    Dave
  2. rich_jtg
    rich_jtg
    Mar 13, 2004
    241
    +13
    You might want to have a look in the FAQ post at the top of this section. ;)
  3. Rasczak
    Rasczak
    Apr 3, 2002
    21,721
    Warwick
    +2,600
    If you just want to copy it to another DVD-RAM then you only need to drag and drop the folder to your DVD-RAM drive assuming you are using Windows XP (DVD-RAM has native support in this version of Windows and thus doesn't require a burning programme).
  4. SDHoward
    SDHoward
    Nov 1, 2004
    250
    Although XP (at least my one) only suports writing to FAT32 format and not udf for which you need another driver.
  5. Rasczak
    Rasczak
    Apr 3, 2002
    21,721
    Warwick
    +2,600
    Yes indeed - but the driver should have been installed when he installed his 4040 - it certainly was on mine.
