PC to Denon 1906
Discussion in 'AV Receivers & Amplifiers' started by WSB, Nov 8, 2005.
Tags:
  1. WSB
    WSB
    Dec 31, 2004
    358
    +7
    Just wondering if anyone can help me on this one...
    I've just upgraded to a whole bunch of new home cinema kit...
    Denon 1906 with Cantons for Speakers. The Cantons only just arrived so havent had a chance to set them up yet.
    I've got a digital out from my sound card on my PC connecting to the optical in of the Denon (no speakers connected just yet). when I plu in headphones to the denon I get no output whatsoever but plugging the headphones directly into the soundcard works fine. I'm hoping its some sort of config thing that I need to do but can anyone help?
    Its a htpc so without the digital output going to the amp I am in dire straits. (i want my, I want my, i want my MTV :lease: )
  2. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,494
    Birmingham
    +205
    Do you have to assign the input used on 1906's?
  3. WSB
    WSB
    Dec 31, 2004
    358
    +7
    dunno- but i'll check. I'm completely new to this- my last piece of kit was a sony dav all in one plug and play type thing and the new setup is daunting to say the least! :rolleyes:
