PC to 27wl56 just a bit of advise,
Discussion in 'LCD & LED LCD TVs' started by Akcron, Aug 28, 2005.
  1. Akcron
    Akcron
    Sep 8, 2004
    164
    +4
    :confused: Does the quality of the vga to vga cable to connect my pc to the tosh 27wl56 effect the end quality of the picture like it does with a scart cable for example...and if it does, does anyone know where i can get a good one ? Also i play games like World of Warcraft online, is the 27wl56 going to give me as good a picture as my 19inch moniter does now, ill be useing 1360 by 768,wide screen settings on the game and sitting about 3-4 feet away,..thx Akky. :)
  2. chowells
    chowells
    VGA is an analogue signal so the quality of the cable will inevitably make some difference. Whether this will be noticeable or not only your eyes can tell.
