PC TFT screen DVI- help
Discussion in 'LCD & LED LCD TVs Forum' started by mhuk05, Mar 1, 2005.
Tags:
  1. mhuk05
    mhuk05
    Jan 17, 2005
    2,721
    J6 M5
    +214
    I've just bought a TFT for my PC. PLugged it in and connected using the DVI (used to use dsub). It looks awful! WHen I look at the forum, all the icons are black, the header is very dark blue - can't see the text..
    Have set it yo 75hz as manual says and have tried adjusting the OSD stuff.
    What's wrong?!!
    help!!
  2. Xelon
    Xelon
    Nov 16, 2004
    391
    +53
    DVI supports max 60Hz, onlt Analogue D-Sub supports 75Hz, change the settings.
  3. mhuk05
    mhuk05
    Jan 17, 2005
    2,721
    J6 M5
    +214
    Cheers! That might explain the occasional "Lines" across the screen.
