PC Svideo to Lg Re44sz21r Not Working
Discussion in 'General TV Discussions Forum' started by nadeem, Sep 5, 2005.
  1. nadeem
    nadeem
    Feb 20, 2005
    126
    16
    Hi all , Had my tv for 4 months now, decided to see how HD clips will look like using svideo connection till i find/get a vga to component cable.
    Problem im getting is that doesnt matter what resolution i select everything is jumping very fast that i cant make out anything.
    According to my manual tv can take 1024 x 768 res.
    Has anyone tried using svideo this way.
    If i try vga to conponent cable will i get the same problem.
    I have MSI geforce 4 TI4200 128mb AGP Graphics card.
    Any help will be appreciated.
  2. dunsters
    dunsters
    Mar 14, 2005
    303
    +7
    I thought s-video was analog signal (as is composite, Scart and even component RGB) and to get those resolutions you will need VGA or DVI/HDMI to display properly?:confused:
    Cheers:hiya:
  3. nadeem
    nadeem
    Feb 20, 2005
    126
    16
    well the strange thing is that before i brought the LG 44" DLP i had the samsung 42" rear projector which worked fine on svideo at 1024x768. So im sure that the LG can take those res on svideo , component might be analogue but it can take high resolutions. AFAIK.
    Update , With svideo its all scrambled
    Any help will be appreciated. :lease:
