PC Spec for video editing?
W
wkm99
I've just ordered a digital camcorder and am looking for some guidance as to the sort of PC hardware I would need to effectively edit the footage I shoot.
MarkE19
Minimum spec I would suggest being:
2gig CPU
40Gb HDD (boot drive)
80Gb HDD (video only drive)
512Mb RAM
Firewire/USB2.0 ports
Graphics card with TV out
But budget allowing I would go up to:
Fastest CPU you can
1Gb or more of RAM
Larger HDD's as required
If you have analogue footage you want to capture/edit then a dedicated internal analogue capture card, or external analogue to DV converter.
DVD writer
Double headed graphics card
Obviously plus all the other required hardware like monitor, sound etc. I would steer well clear of onboard graphics, but onboard sound should be good enough.
Mark.
W
wkm99
Looks like I need a new PC then!:thumbsdow
Better get saving as it sounds expensive.
Thanks for the help.
MarkE19
Depends on what you call expensive.
You should be able to get the lower spec PC I listed for around £500. The better specs should only cost another £200 ish. Of course you could start to look for things like real time effects etc on the capture card with hardware codecs etc and spend a couple of grand on that alone :eek:
Mark.
Podcast: LCD TVs for Movies, Physical Discs?, RIP Ennio Morricone, AV & Movie news, B+W Matt Damon
