PC spec for HD via Satellite
Discussion in 'TVs' started by Tony B, Apr 8, 2005.
  1. Tony B
    Tony B
    Oct 29, 2004
    536
    +18
    I have the chance to buy the following spec PC at a very favourable (and tax efficient) cost.
    Will it be up for the job of receiving HD stuff via satellite?
    * Hewlett Packard T860
    * CPU Intel Pentium 4 Processor 540 (3.2GHz) HT
    * Monitor 17" TFT - but I would use my 37pf9986 for this
    * Memory 512MB DDR SDRAM
    * Hard disk 200GB-7200rpm
    * Optical drive #1 DVD drive 16x max
    * Optical drive #2 DVD writer double layer +/-R +/-RW 16x max
    * Graphics ATI RADEON X300SE (VGA port, TV-out)
    * Sound Intel High Definition Audio 7.1
    * IEEE1394 / Firewire 2
    * Network interface 10/100BT network interface
    * Operating System Microsoft Windows XP Home Edition
    * Plus TV and FM radio tuner card with remote control
    Also - does anyone know the cost of an HD1 card, without the receiver?
    TIA
    Tony B
  2. laser
    laser
    Aug 1, 2004
    924
    Hartlepool
    +28
    Yes. It will be OK.
    The graphics card is 128MB so will be OK.
    512MB of RAM is adequate but you can always upgrade if you need to.
    No idea about a HD1 card though.
  3. johnelf
    johnelf
    Nov 10, 2003
    632
    Epsom
    +78
  4. Tony B
    Tony B
    Oct 29, 2004
    536
    +18
    Thanks for your responses.
    Are you saying that 512MB RAM is a bit marginal then?
    The PC purchase deal is via my employer, and apart from 3 models of PC (of which this is the most powerful) there is no choice on spec.
    Total cost would be about £700.
    Add the Skystar card at ca £60, plus the HD1 card at £x, and an Irdeto CAM for the pc at about what £80 - £100?
    Starting to make the Quali-TV 1080IRCI @ ca £530 including card, look a bit reasonable (as I do already have a pretty good laptop for normal use)....
    What do you reckon, chaps?
  5. 1080 jawbreaker
    1080 jawbreaker
    Nov 30, 2004
    2,805
    +635
    the Quali-TV 1080IRCI will only recieve mpeg2 encoded channels so will be off no use for HD-2 which will launch in a few months using an mpeg4 variant.
  6. johnelf
    johnelf
    Nov 10, 2003
    632
    Epsom
    +78
    Tony
    I think you are being ripped off by your employer. I got a new Dell P4 3.2 With 1gh of Ram and a 320 hard drive 256 mb 6800 GTO nvidia graphics card fromm Dell factory site for £479 inc del and and vat. This is what i am using for exactly what you are doing. If you want a 17inch flatscreen they are £155 all in. Far cheaper than what you are paying and 1yrs warranty and far higher spec.
    And yes i would go with min 1ghz ram and as fast a pc as you can afford.
    John
  7. Muf
    Muf
    Sep 11, 2003
    412
    IRL
    +8
    jawbreaker, HD-2 will be available in both mpeg2 and mpeg4 but mpeg2 will cease in 2008.
    Jim.
  8. 1080 jawbreaker
    1080 jawbreaker
    Nov 30, 2004
    2,805
    +635
    i heard diffrently. That hd-1 would be mpeg2 and mpeg4, were as the new hd-2 would be mpeg4 only?
  9. Muf
    Muf
    Sep 11, 2003
    412
    IRL
    +8
  10. 1080 jawbreaker
    1080 jawbreaker
    Nov 30, 2004
    2,805
    +635
    cool, at least if ya have just shelled out for the reciever and card bundle
