PC speaker splitter.
Discussion in 'Cables & Switches' started by Dj_Sim, Feb 2, 2009.
  1. Dj_Sim
    Dj_Sim
    May 27, 2006
    655
    Kent
    +14
    I have 2 computers next to each other, I need to share my one set of speakers with both machines.
    I am looking for a website to order one from but no luck.... tried maplins.
  2. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,280
    Manchester
    +763
    Wouldn't a speaker switch be easier - and get around any contention or load problems (because you won't then be able to have 2 in parallel, which would about halve the impedance and could result in signal starvation or even damage).
    Chris Muriel, Manchester
  3. stug45
    stug45
    Jan 25, 2009
    57
    +4
    is it not possible to have the set of speakers playing both signals?
  4. Dj_Sim
    Dj_Sim
    May 27, 2006
    655
    Kent
    +14
    Only one machine will be on at a time.
    I dont fully understand your reply?
  5. mossym
    mossym
    Apr 5, 2006
    13,152
    Ireland
    +2,802
    get one of these..
    Four-Way Stereo Audio Switch Box > Maplin
    and some 3.5mm to phono cables, connect both pcs to separate inputs on the switch using these, then connect the speakers to the output of the switch using a male phono to 3.5mm female adapter. all are available from maplin..
  6. Dj_Sim
    Dj_Sim
    May 27, 2006
    655
    Kent
    +14
    Shorley I can do that with just a cheap wire?
  7. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,280
    Manchester
    +763
    Mossym highlighted just what I was recommending - a simple speaker switch.
  8. mossym
    mossym
    Apr 5, 2006
    13,152
    Ireland
    +2,802
    not without possibly causing damage to your seakers or pcs. if you're willing to swap the cable between the pcs every time then yes you can do it with a simple wire
  9. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,756
    The Borders
    +3,520
    Hello Dj Sim
    You need to provide a bit more info before folk can advise you on this one.
    When you say Speakers do you mean HiFi type 'passive' speakers that are powered by an external Amplifier or the Active type that have an on-board amplifier (the norm for small desk top PC speakers).
    If you have Active Speakers then you require a 2x1 Source selection Switch - which is very different from and a lot less costly than an Amplifier selector switch that lets you share one pair of Passive Speakers between two amplifiers.
    If you employ a 'Y' cable between two line out sources (your PC's) and the line in on a set of active Speakers you run the risk of damaging your kit - better to buy a switch.
    Joe
  10. Dj_Sim
    Dj_Sim
    May 27, 2006
    655
    Kent
    +14
    Thanks guys.
    They are active speakers, I am going to buy a new KVM with audio support.
