PC (SPDIF) -> AV & DVD -> Amp
Discussion in 'Cables & Switches' started by Lostinapc, Aug 19, 2004.
  1. Lostinapc
    Lostinapc
    Hey! :hiya:
    I have two soundcards on my PC both with SPDIF, i think that is spelt right.
    I believe this is a digital signal and am wondering what lead i will need to connect this to my amp ((probably a budget denon) when I get it) so that I can plug it into the optical slot.
    I think that is where it will be going.
    Also what connection is best from my DVD -> Amp? coaxial or optical?
    Thanks!
    Robert
    :thumbsup:
  2. ReggieDaMole
    ReggieDaMole
    Aug 18, 2004
    189
    19
    The fields of Anfield Road
    OK here goes
    AUDIO ONLY
    PC SPDIF OUT >>>>>> OPTICAL TOSLINK CABLE >>>>>> AV AMP SPDIF IN
    DVD PLAYER DIGITAL COAX OUT >>>> DIGITAL COAX CABLE >>>> AV AMP DIGITAl COAX IN
    Therefore you need an AV AMP with at least 2 digial INS (1 coax, 1 optical)
    Aye
    Reg
  3. Lostinapc
    Lostinapc
    Thanks,
    so there is a SPDIF In on the amp? is that the Optical Digital In?
    (sorry, I don't yet have the amp, getting it in a week probably so want to get it all sorted before i set it up)
    coax is best then for carrying the signal between the dvd & amp.
    Thanks again!
    Robert
  4. ReggieDaMole
    ReggieDaMole
    Aug 18, 2004
    189
    19
    Yes & Yes
    UR welcome
    Reg
