PC Restarting
Discussion in 'Desktop & Laptop Computers Forum' started by Jazz Monkey Jr, Mar 29, 2005.
  1. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,029
    2
    4
    137
    Garstang, Lancs
    +1,584
    My PC has recently started restarting when I try to run the virus checker. Also if I try to search after searching for a few seconds the screen goes then comes back on but the search has stopped and gone!!! It is OK when using word, using the internet etc... :confused:
    I have tried running Ad-ware and Spybot but it still does it.
    It is annoying as I can't run a full viurus check.
    I am using WinXP pro, Athlon 2800, 1024MB DDR400, Geforce Ti4400, 2 x 250GTB S-ATA HDD.
  2. jlcrawford
    jlcrawford
    Mar 21, 2001
    487
    NE England
    +3
    i have just had this problem with a works PC.It had adware which I removed but it continued and then yesterday the PSU popped and took with it mobo CPU and HDD - Id check your PSU if I were you
  3. martin123
    martin123
    if its restarting it'l more than likely be a hardware not software problem. You can disable it restarting by right clicking on My Computer then going to:
    advanced>start up & recovery settings> & untick automatically restart
  4. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,029
    2
    4
    137
    Garstang, Lancs
    +1,584
    OK, thanks for your advice
