PC Remote Control for PowerDVD 6
Discussion in 'Desktop & Laptop Computers Forum' started by nwgarratt, Jun 8, 2005.
  1. nwgarratt
    nwgarratt
    May 5, 2002
    27,031
    +2,979
    I currently have a Netshooter remote from six years ago. It doesn't work so well anymore. Sometimes it works and sometimes it doesn't. I think the move from Windows 95/98 to XP hasn't helped.
    Is there any better remotes than can work with PowerDVD 6. I wouldn't mind one that has specialist custom buttons for PowerDVD's functions.
    Can any of them work of a USB port?
    Thanks.
  2. Harryo
    Harryo
    Oct 11, 2004
    112
    Merseyside
    +6
    I am using a StreamZap remote with Cyberlink DVD 6 and it appears to work ok, although I have only had it for a day!
    You can check applications functionality here:-
    http://www.streamzap.com/support/remotehelp/PCRemote.htm
    It uses an IR sensor which plugs into a spare USB port, the driver supplied on the accompanying CD was slightly outdated the latest driver is available on the StreamZap website.
    The cost was £23.50 plus postage from a UK dealer.
    Harryo
  3. nwgarratt
    nwgarratt
    May 5, 2002
    27,031
    +2,979
    Thanks. I'll have a look.
  4. nwgarratt
    nwgarratt
    May 5, 2002
    27,031
    +2,979
    Does anyone know if the ATI Remote Wonder will work with PowerDVD 6?
    I like the idea of a radio controlled remote.
  5. Harryo
    Harryo
    Oct 11, 2004
    112
    Merseyside
    +6
    There is a good review of the ATI Remote Wonder II at the following website:-
    http://www.remotecentral.com/index.html
    They also have various forums so you might be able to find the answer to your question there.
    If you do a search on Google it comes up with a lot of hits on the ATI, also in certain quarters it is also known as "BOB II" !
    Harryo
