PC powering on by itself !!
Discussion in 'Desktop & Laptop Computers Forum' started by Geordie Jester, Sep 17, 2007.
  1. Geordie Jester
    Geordie Jester
    Oct 14, 2003
    1,437
    +156
    Anyone had this before.....???
    A new PC with XP........ When "turning off" from shutdown menu, PC shuts itself off, then 4 seconds later powers itself back on by itself. We have checked the Bios for any auto-on settings etc and can't track any reason.
    Bit more info....... problem goes away if we unplug the USB wireless adapter device. It is somehow triggering the motherboard to power back on just after powerdown. Does that point towards anything ?
    cheers
  2. Leslie999
    Leslie999
    Dec 19, 2006
    50
    +5
    It sounds like you have "wake up on lan" enabled. Have a look for it in the bios settings and disable it.
  3. Geordie Jester
    Geordie Jester
    Oct 14, 2003
    1,437
    +156
    Thanks, but we checked all of that. It's all disabled.
    After a bit of a search on the 'net it looks like this can happen with USB devices and in a few other instances. Very strange
  4. Member 79251
    Member 79251
    Jul 2, 2005
    13,421
    +2,187
    It would be your usb, I have the same issue if any usb cables are plugged in the machine stays alive. Remove them and it powers down fully.
