PC output on Grand Wega or Loewe?
Discussion in 'General TV Discussions Forum' started by phil_evans, May 25, 2002.
  1. phil_evans
    phil_evans
    May 24, 2002
    186
    16
    Singapore
    I'm looking for a wide-screen TV (min 32", max 50") that can also serve as a semi-decent PC monitor (working/ surfing from my laptop). I'm looking for it to support XGA (1024 x 768) or, ideally, Wide XGA. My budget is upto about £4k.
    I see Loewe TV's have a VGA upgrade module, but presume this is limited to 640x480 VGA (or WVGA at best). Does anyone have experience of using the Loewe VGA module as I can't get any specs off the web-site?
    I also think that the stunning new Sony Grand Wega (at limit of my budget) - the 50SX200 - has WXGA (or some form of mega-pixel) LCD panels. Again, does anyone know if it supports an XGA PC output?
    Any first-hand experience, would be much appreciated.
    Great forum, by the way!
    Phil
  2. Garrett
    Garrett
    Apr 21, 2001
    42,148
    2
    167
    The best thief you'll never see.
    +7,672
    Hi Phil
    If no one replies or you have the time try the search button at the top of the page, then use the word search. There is a lot to trawl through but there very well could be a post which mentions the VGA card.
    I have a Loewe, am highly delighted with it so are most other owners.
    Best of luck.
  3. groundy
    groundy
    Dec 8, 2001
    1,554
    39
    Northern Ireland
  4. phil_evans
    phil_evans
    May 24, 2002
    186
    16
    Singapore
    Thanks groundy/Garrett - guess I need to practice my searches a bit more.
    So that clears up the CRT question - even with the Loewe VGA module, XGA resolutions are not really an option.
    Anyone out there lucky enough to have a Sony Grand Wega? Have you investigated the PC-out options?
    Otherwise - I guess I need to keep saving for a modern plasma or, perhaps I'll get a decent 36" Philips P+ and buy a decent TFT panel (monitor) as well.
  5. Guest
    I have the Sony Grand Wega KF-50SX100 and it does not have any PC-out options. There is the new model KF-50SX200 but no mention of a PC connection in the Sony book.
