PC or emac???
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by forest, Dec 18, 2003.
  1. forest
    forest
    Hello, I've got a max budget of£1000 to spend on a computer which I want to use for DV editing --should I get a an emac or PC?
    Thanks.
    :laugh:
  2. Duncan Craig
    Duncan Craig
    Jun 1, 2003
    258
    The Grim North
    +17
    The eMac is a great machine.
    Fast G4 proc. Light and portable. TFT.
    It's shipped with iMovie editing software, which should do you quite well I think. Or look at Final Cut Express.
    Get Maxtor One Touch or Lacie External Firewire drives for extra storage.
    A pioneer 105/6 in an external Firewire box would do you for burning DVDs
    Someone may know if the eMac ships with iDVD?
  3. tomson
    tomson
    Jul 19, 2000
    1,918
    Berk'amsted
    +187
    The superdrive equipped one does
  4. Frankie_D
    Frankie_D
    Oct 19, 2003
    177
    Hampton Court, no not the palace!
    hey forest do you mean eMac or iMac, the eMac is like the old iMac shape, and the current iMac has a flatscreen.
  5. Tunes Man
    Tunes Man
    Forest, my suggestion would be to get a mac. I bought a Power Mac G4 1250 mini tower to use just for video editing and am very happy with it. When I bought it, I also purchased the "Final Cut
    Express" video editing software and it works great. I'm still learning how to use it, but what I've found it can do so far is pretty awsome. I've mainly used pcs for years so it took me a little while to get used to using a mac for the first time, but they're not that much different from a pc.
    Anyway good luck on your decision.
    Tunesman.
