Question Pc Optical Drive
Discussion in 'Computer Components' started by AbuAbdullah, Jul 11, 2015.
  1. AbuAbdullah
    AbuAbdullah
    Oct 9, 2009
    2,811
    Birmingham
    +110
    Bit of a noob question...i need an optical drive to make audio cd's but the one i have only reads cd's. So which one do i need?
    Thanks.
  2. sep8001
    sep8001
    May 2, 2008
    2,736
    103
    +320
    You need a cd writer or a DVD writer. Generally the DVD writer will do cd and DVD so bet to get a DVD writer.
  3. AbuAbdullah
    AbuAbdullah
    Oct 9, 2009
    2,811
    Birmingham
    +110
    Thank you.
  4. paulktreg
    paulktreg
    Feb 27, 2011
    940
    46
    Clitheroe
    +131
    If yours only reads CD then I'm assuming it's old tech and could be an IDE interface?
    If not then it's probably SATA.
  5. AbuAbdullah
    AbuAbdullah
    Oct 9, 2009
    2,811
    Birmingham
    +110
    It's sata but 'DVD Multi Player'
  6. paulktreg
    paulktreg
    Feb 27, 2011
    940
    46
    Clitheroe
    +131
    If it's SATA then that's OK.
    If you fancy Blu-Ray as well then something like this will burn them all?
  7. EndlessWaves
    EndlessWaves
    Apr 7, 2008
    13,943
    Norfolk
    +2,549
    Generally drives with multi or super in the title are capable of writing disks, are you sure yours isn't?
  8. AbuAbdullah
    AbuAbdullah
    Oct 9, 2009
    2,811
    Birmingham
    +110
    Yes iv'e tried but it does not recognize a blank disc. It only reads discs with content on them.
