PC onto your TV with HD, Please explain
Discussion in 'General TV Discussions Forum' started by skaps, Mar 19, 2005.
  1. skaps
    skaps
    Oct 31, 2004
    45
    can anyone tell me how you put hi def material into my laptop and display it on my sagem50" :lease:
    layman terms please :thumbsup:
  2. KableMan
    KableMan
    Feb 9, 2005
    610
    Solihull
    +88
    Hi skaps
    Step 1. download a demo from here:
    http://www.microsoft.com/windows/windowsmedia/content_provider/film/contentshowcase.aspx
    pick a 720p or 1080p (both are HD but the latter is higher definition). The minimum PC spec is listed here too.
    Step 2: Download windows media player 9 or 10 (you may already have these), or zoomplayer from here:
    http://www.inmatrix.com/files/zoomplayer_download.shtml
    Step 3: plug your laptop into the sagem 50 via its PC VGA connection - just like you'd plug your laptop into a monitor at home or at work. Not sure what resolution the sagem supports but try 1280x720 at 60Hz as this is the most common. This is the trickiest bit of the lot - you may find other threads that tacle this step in more detail.
    Step 4: And then play the demo using the player. You should then be seeing HD material on your sagem just like in comet.
    Good Luck
    KableMan
  3. skaps
    skaps
    Oct 31, 2004
    45
    thanks, i will give it a go
  4. St_ve
    St_ve
    Jan 6, 2005
    1,059
    39
    Birmingham
    skaps stay away from the demo's with DRM (Digital Rights Management) as they need you to have an American IP adress & won't work in the UK
  5. Razor
    Razor
    Dec 15, 2004
    37,727
    2
    +12,503
