PC Now not booting at all
Discussion in 'Desktop & Laptop Computers Forum' started by dUnKle, Sep 3, 2007.
  1. dUnKle
    dUnKle
    Jan 1, 2001
    15,931
    +2,920
    Trying to fix my PC up to a useable state whilst I save up for an Imac
    Anyway things where sort of going well until reboot
    The PC just hangs at the point where you should be able to press DEL to access the Bios
    No matter how long I leave it it does not move on or go any further - pressing DEL does not access the Bios
    Have tried booting bootable disc and USB drive in but nothing - just hangs
    Is it fixable ?
  2. Andy98765
    Andy98765
    Feb 15, 2006
    10,474
    2
    +1,367
    You could try clearing the CMOS memory of the Motherboard, there is usually a little link next to the onboard battery for doing this (or remove battery for 10-30 secs). BUT remember you will clear all settings.
    SATA hard disc booting etc
    The Date and time will need inputting straight away.
  3. joshua_bond
    joshua_bond
    Jun 25, 2002
    354
    +16
    Well generally most things in a PC's life is possible to fix.
    We will need a bit more info..
    Operating system?
    events leading to outage?
    Any dreaded "blue screan of death"?
    Self-build PC?
    PS. have you tried other buutons e.g. F1 or F5 or F9? Sometimes other buttons accesses the PC's BIOS.
  4. Miss Chief
    Miss Chief
    Jun 12, 2007
    7,823
    +1,187
    I hope you checked the obvious, everything inside the PC seated properly, all leads and connections tight and good? Something as simple as a loose connection could easily cause a problem like this.
    Are there any bios Beeps? Remove any cards and devices you don't actually need such as extra DVD/CD drives, sound cards etc so you're at the bare minimum required to boot and try again.
