Question Pc not booting
Discussion in 'Desktop & Laptop Computers Forum' started by Cannonball54, Jan 12, 2018.
Tags:
  1. Cannonball54
    Cannonball54
    Jul 24, 2016
    40
    11
    Wales
    +3
    Ok.
    Just built my first pc.
    And all that is working are. Mb lights up power button is lit up case and cooler fans work. That' it. No hdd activity light. No reset no usb sockets working 2.0 or 3.0. Either from the mb or the case.
    Wont' boot into anything. Not even bios im using asus prime mb. 16gb ddr4 dominator platinum and i5 7600k.
    Done loads of checks over and over. Any help would be great.
    Tnx Rob....
  2. Russ_64
    Russ_64
    Jan 20, 2005
    567
    2
    London
    +292
    Any BIOS beep sounds? Could be that CPU is not seated properly or RAM is incompatible. Try with only one stick of memory. Google can also help to find possible fixes.
  3. Cannonball54
    Cannonball54
    Jul 24, 2016
    40
    11
    Wales
    +3
    Tnx mate. No bios bleeps cpu is ok I have tried reseating it. Not tried ram. But it is compatible and can' find owt on Google. Lol
  4. John7
    John7
    Aug 6, 2004
    2,818
    +982
    Have you connected the aux 12 volt supply to the mb (square 4 pin plug that connect top rear of mb)?
  5. Cannonball54
    Cannonball54
    Jul 24, 2016
    40
    11
    Wales
    +3
    Tnx John will look now
  6. Rowan J Parker
    Rowan J Parker
    May 17, 2013
    71
    Glasgow
    +58
    For whatever reason the motherboard is failing to POST. Try just one stick of ram in the first DIMM slot, swap out single ram sticks as it's possible one stick is faulty which can cause post failure.
  7. Cannonball54
    Cannonball54
    Jul 24, 2016
    40
    11
    Wales
    +3
    Hi mate that was not connected and is an 8 pin on my mb.and whn I connect it. It just keeps shorting out
  8. Cannonball54
    Cannonball54
    Jul 24, 2016
    40
    11
    Wales
    +3
    Tried that rowan no luck
  9. only1hammy
    only1hammy
    Mar 19, 2008
    575
    3
    67
    Finland
    +305
    Can you elaborate what you mean by "shorting out"? You'll need both 20/24-pin and 8-pin connected for everything to receive enough power.
    Try to boot without any RAM installed and listen for beeps (assuming your motherboard has an internal speaker).
    Could also list exactly which ASUS Prime you have and your PSU model?
  10. John7
    John7
    Aug 6, 2004
    2,818
    +982
    You must have th 8 pin connected or it will not boot!
  11. Cannonball54
    Cannonball54
    Jul 24, 2016
    40
    11
    Wales
    +3
    Soz mate wot I mean is wen I connect the 8 pin to the mb it keeps stopping and starting every 5 secs strange I know my mb is asus z270 prime A. Thx
  12. Cannonball54
    Cannonball54
    Jul 24, 2016
    40
    11
    Wales
    +3
    Wont even start if I connect the 8 pin conbectir
  13. Cannonball54
    Cannonball54
    Jul 24, 2016
    40
    11
    Wales
    +3
    Connector
  14. AnthonyG
    AnthonyG
    Nov 23, 2005
    8,856
    +1,188
    What power supply do you have. Make, model and wattage?
    And just to confirm the power supply has a 8 pin CPU connector on it that you have attached?
    Does your motherboard have a DVI or HDMI connector on the back that you could try booting without the grahics card installed at all (i.e a massive PSU drain) to see if it still cuts out.
  15. Cannonball54
    Cannonball54
    Jul 24, 2016
    40
    11
    Wales
    +3
    Hi mate thx.
    Wattage of psu is 800w don' jknow make. Just gerenic
    Yeah gave power supply and 8 pin connector
    And I gave tried just connecting from the mb using hdmi as I don' h a dvi monitor
  16. Russ_64
    Russ_64
    Jan 20, 2005
    567
    2
    London
    +292
    What storage devices are connected? M.2 or Intel Optane?
    Try to remove everything and get it to boot into BIOS with just CPU & RAM.
  17. NinjaMonkeyUK
    NinjaMonkeyUK
    Aug 1, 2004
    1,013
    +270
    List your exact specs and we may be able to help you. I suspect you might be shorting the motherboard against the case; did you install the risers or did you screw the motherboard directly to the chassis?
  18. Cannonball54
    Cannonball54
    Jul 24, 2016
    40
    11
    Wales
    +3
    Hi thx for reply yeah I installd a of the risers my specs are.
    Cpu i5 7600k
    Mb Asus z270 prime a
    16gb ddr4 ram
    Cryorig a40 cpu cooler
    1tb seagate machanical hdd
    Case be quiet dark base 900 pro
  19. Cannonball54
    Cannonball54
    Jul 24, 2016
    40
    11
    Wales
    +3
    Hi folks.
    Just found out the pins on my mb have been bent (by me) so looks like new mb. Omg. Only had this one 3 weeks. Looks like I've learnt the hard way.
    Thx for all ur input
    Rob..
  20. NinjaMonkeyUK
    NinjaMonkeyUK
    Aug 1, 2004
    1,013
    +270
    Are you sure you can't just bend them back into place?
  21. wiz
    wiz
    Aug 20, 2000
    4,566
    +4,555
    Indeed, if you look on YouTube you'll find a guide as to how to do it!
  22. Cannonball54
    Cannonball54
    Jul 24, 2016
    40
    11
    Wales
    +3
    Took it to my local pc shop and he said there is too many bent (about 20) pins to do that.
    Just a quick question will my cpu be OK to use in a new board. As don' want to replace that as well.
    Thx...
  23. Russ_64
    Russ_64
    Jan 20, 2005
    567
    2
    London
    +292
    You mean the pins in the CPU socket are bent? Wow - how did you do that? Or maybe it was like that - a bad MB? You could try to return it as faulty .......
    As for CPU - it may be okay but you will have to try it in a new MB to tell for sure..........
  24. NinjaMonkeyUK
    NinjaMonkeyUK
    Aug 1, 2004
    1,013
    +270
    They might have told you that because they would rather sell you a new motherboard. If it's 20 pins then you should be able to move them back into place. Just be careful.
    I'm not sure how you managed to bend them in the first place to be honest; all you have to do is drop the CPU into the socket so there shouldn't be any force applied on the pins.
  25. Cannonball54
    Cannonball54
    Jul 24, 2016
    40
    11
    Wales
    +3
    Yeah thx all.
    I know I didn't put much force on the pins.
    Wen putting in the cpu. I know I didn't
    Not sure how I managed to do this either.
  26. Varsas
    Varsas
    Nov 23, 2015
    98
    19
    UK
    +46
    Attaching the heatsink would have put force on the pins, I assume that's how it happened. I dare say you had the CPU the wrong way round in it's socket.
    We've all made mistakes, if you don't try you won't learn.
    As others have said it might be possible to bend the pins back, if the m'board is scrap anyway you don't have anything to lose!
  27. Cannonball54
    Cannonball54
    Jul 24, 2016
    40
    11
    Wales
    +3
    Hi folks.
    Just to say thx for the replys
    I send my board back to where I bought it from.
    And they have just agreed to replace it
    And have just dispatched it to me.
