PC Music Playback Software
Discussion in 'Desktop & Laptop Computers Forum' started by Jon, Sep 16, 2004.
  1. Jon
    Jon
    I am in the process of setting up my pc as a juke box and was wondering what software would be best for music playback, I have realplayer, is there anything better in terms of sound quality?
    Jon
  2. SimonInd
    SimonInd
    May 9, 2001
    209
    London
    For the best sound quality you ideally want a good soundcard, probably from a music rather than computer hardware manufacturer: e.g. M-Audio, RME, Lynx, and then you want to make sure that the digital data gets from your harddrive to the soundcard without being altered - ASIO drivers for the music players will ensure this. You obviously need to store the music in a good quality format as well - high bit rate mp3 or a lossless compression algorithm ( e.g Monkey's Audio ).
    I use WinAmp with an ASIO plugin and a M-Audio Audiophile 2496 soundcard and am very happy with the sound. I store CD's in Monkey's Audio (.ape) format files and buy alt.preset.extreme LAME encoded mp3s.
    Hope this get's you on ther right track
    Simon
  3. Jon
    Jon
    Hi Simon,
    My amp has a USB input so am intending to use this, although i havnt tried it yet so dont know how good it is, i have heard that it is very good though. I havnt heard of Monkey's Audio so will have a search on the web for that. Thakns for all your suggestions, its very much appreciated!
    jon
