PC Looks HORRIBLE via DVI - Samsung ln-t3732h
Discussion in 'Samsung TVs Forum' started by jfontestad, Jan 31, 2009.
Tags:
  1. jfontestad
    jfontestad
    Jan 31, 2009
    Hello all,
    I'm having a little headache here. Not too long ago I decided to upgrade my PC video card to a Sapphire x1650 Pro 512MB. It has standard DVI, VGA, and S-Video outputs on it. I have it hooked up to my 37" 780p Samsung LN-T3732H. At first I had it hooked up via VGA and it looked pretty sharp. Text was clear and everything looked good.
    Then I thought well if it looks this good via VGA imagine how well it would look with the DVI hooked up. So I bought a HDMI to DVI cable and hooked it up the the TV. Well needless to say... resolution is bad... it doesn't even fill up the entire screen. I have it set to 1360*768 @ 60hz. Text looks pixely and I can not find anywhere on how to make it fill the screen as well as provide a clear sharp picture.
    I'm starting to think maybe I should just switch back to VGA.
    Can anyone shed some light on how to maybe fix this or should I just switch back to VGA?
