Hi, I`ve got Nero & the way I use PCline labels with it is:-
In the top box; select the maker`s name "Hisago CJ4844S (A4)".
Then go to FILE, & scroll down to PREFERENCES & click.
Click the PRINTING tab.
Under "Printer Calibration", change the numbers in the left box to -6.000mm
& the right box to 5.500mm. Click OK.
Then you can go to SAVE AS & save this as a Nero Cover Designer Document
on your desctop for future use.
You can then use it in the normal way, but the printing should align with PC line paper.
