PC Input On Bravia S Series
Discussion in 'LCD & LED LCD TVs Forum' started by fredericmcc, Mar 26, 2006.
Tags:
  1. fredericmcc
    fredericmcc
    Feb 20, 2006
    54
    +3
    Hi all, quick question about the PC input on the S series Bravia's, namely the 23" which I'm helping sort my mum out with. I want to connect her PowerBook to it via VGA (Converted from the machine's DVI with Apple supplied cable) and am working out which type of VGA cable i'll need, as am not sure whether the Bravia accepts a male or female cable.
    I'm thinking of buying http://www.amazon.co.uk/exec/obidos...UTF8&coliid=I16D945ZM0YLI9&colid=IQWAKZGWIVID from Amazon, will this cable work, or do I need a male to female type cable?
    Thanks for your help
  2. dodger747
    dodger747
    May 5, 2005
    2,976
    Liverpool
    +209
    You can always buy a gender converter if you have the 'wrong' lead...:thumbsup:
  3. fredericmcc
    fredericmcc
    Feb 20, 2006
    54
    +3
    Thanks, I realise that, but want to try and not waste unnecessary pounds!
  4. DaveP
    DaveP
    The TV will have a female socket so you need a male terminated cable
  5. fredericmcc
    fredericmcc
    Feb 20, 2006
    54
    +3
    Thanks for that Dave
