PC hook-up to Panasonic DLP PT-50DL54
Discussion in 'TVs' started by moparman, Apr 20, 2005.
Tags:
  1. moparman
    moparman
    I want to hook up my PC to my Panasonic DLP PT-50DL54 TV using RGB or HDMI. Is there a way to get it to work in wide screen? The manual says "Aspect is not available while in RGB and HDMI mode." I have had it working full screen with an S-cable but I am not all that happy with the picture quality. Any suggestions would be greatly appreciated.
  2. Razor
    Razor
    Dec 15, 2004
    37,548
    2
    +12,508
    Are you using a pc or dvd player. Is the panasonic a DLP tv, if it is, it isnt availible in the UK yet.
  3. Razor
    Razor
    Dec 15, 2004
    37,548
    2
    +12,508
  4. indie24
    indie24
    Oct 3, 2004
    882
    46
    london
    +200
    i doubt it will be released in uk.
  5. moparman
    moparman
    Razer it is a pc running windows xp pro. Cable is RGB out to RGB in and get 4.3 aspect not full aspect is there away around it . thanks
  6. Razor
    Razor
    Dec 15, 2004
    37,548
    2
    +12,508
    Have you not got a DVI/HDMI connection. If so use this as its the best connection, if not look or a VGA connection. :D
    Set you graphics card to 1280x720 on your desktop and update your drivers. You will now get full screen.
    :thumbsup:
    DVI/HDMMI has 1:1 pixel mapping.
