pc help pretty please
Discussion in 'PC Gaming & Rigs' started by Miyazaki, Jul 25, 2005.
  1. Miyazaki
    Miyazaki
    Sep 10, 2003
    14,391
    +850
    I have formatted my laptop and installed xp pro on there, but when I start up it asks me to choose an operating system, and still has xp home listed. However when I choose this option it says it isn't installed, yet still asks me which operating system I want to use! :confused:
    how do i get rid of this prompt?
    Many thanks.
  2. HMHB
    HMHB
    Nov 11, 2001
    26,724
    Nottinghamshire
    +5,490
    Right click on my computer and then click on Properties. Then click on Advanced, then click the settings button for Startup and Recovery. There you will be able to pick the default OS or edit the file which gives you the choices.
  3. pragmatic
    pragmatic
    Nov 9, 2004
    12,150
    +1,647
    press windows key + r and type msconfig and you have the option to change the boot setup ect... Check the boot.ini section
  4. iZombine
    iZombine
    Jan 21, 2005
    873
    28
    +33
    Boot up from your XP Pro CD go into the recovery console and type fixmbr.
    OR
    Look for the boot.ini file and remove Xp Home from the list. You might have to turn off " Hide protected operating system files " which is found in the folder options in the control panel.
    The boot file looks like this:
    [boot loader]
    timeout=30
    default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
    [operating systems]
    multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Home Edition" /noexecute=optin /fastdetect
    Your's should have xp home and xp pro. Remove the XP Home line.
    Hope that helps.
  5. HMHB
    HMHB
    Nov 11, 2001
    26,724
    Nottinghamshire
    +5,490
    It's already been sorted in the duplicate thread in General Chat
  6. Miyazaki
    Miyazaki
    Sep 10, 2003
    14,391
    +850
    Sorry again :rolleyes: :blush: :D
    I actually just reformatted again and it disappeared.
    I wouldn't recommend anyone install x64 windows. It is a nightmare!
