PC + HD1 stb -> HDTV display ??
Discussion in 'General TV Discussions Forum' started by Ak1s, Feb 16, 2005.
  1. Ak1s
    Ak1s
    Hi all,
    I would appreciate your views and opinions on this. I have been looking through the threads and on websites and I am still confused! Please feel free to redirect me to other threads if some things have already been discussed:
    I am designing a new system whereby I can use a PC with DVI for playing the following:
    - video on hard disks (DivX, WM9 etc)
    - DVDs (of the standard variety, and of the HDTV variety soon)
    - games
    and also get a STB + dish to access HD1 and soon HD2 content.
    For video output I am thinking PT-AE700 projector (with DVI->HDMI cable).
    For sound output I am thinking a 7.1 AV receiver (Onkyo or some other).
    My questions are:
    (A) For HD1/HD2
    i. to whom do I need to pay the subscription? Do I need to find a local distributor/satellite shop? It's not clear from the HD1 website.
    ii. How do I get the CA card?
    iii. Is QualiTV the only stb I can use? I've heard they are v.expensive ($500+). Is there a list of compatible stbs I can look through?
    iv. What about MPEG-4 compatible stbs? It would be better to get an MPEG4 stb, as I am planning to have the whole system completed by June 05 anyway.
    (B) Any issues you foresee or suggestions you may have for the rest of the setup are welcome. I don't aim for a very expensive system, plan to fit all this within a £4.5K budget, including some Kefs KHT2005.2. Or £3.5K if I use temporarily one of my existing PCs, which is not too old (and still plays WM9).
    Long questions I know, thanks for reading :):)
  2. cwick
    cwick
    Feb 4, 2002
    2,231
    Reading
    +95
    Why get an STB when you've got a PC connected ? A PC DVB-S card is waaaay cheaper than the STB. Get one with a CAM slot, either built-in, or as a daughter card, and you're good to go.
  3. Ak1s
    Ak1s
    Thanks, sounds good, any brands or online shops or links etc?
    Will it play MPEG4?
  4. cwick
    cwick
    Feb 4, 2002
    2,231
    Reading
    +95
