Pc HD Problem for Sammy 32" HD BDX
C
Chris White
Ive hooked up my new sammy and need to try and get my pc to play HD content so I can see how good HD is.
I went on to the net last night to W MEdia Player HD and downloaded the T2 trailer. I did a test on my pc from the site to determin wheter it can play HD and it said it could apart from the fact I havent enabled AGP fast wire?. can anybody help me enable this on my FX5200 or maybe its a FX5500?. I spent an hour trying to find out where I could turn this on but cant find it? If i can get my pc playing HD movies i want to test how good it will be.? What lead is best to hook up a pc to this tv?
What is AGP Fast Wire?
Chris. :lease: :lease:
Think EDDS meant BIOS - ISTR it is an AGP option in the BIOS? (Is it FAST WRITE rather than FAST WIRE?)
Thanks guys, I didnt get chance to take a look last night and am planning on doing it tonight/this week end. Ill keep you updated.
thanks and respect :thumbsup:
Its actually AGP Fast-Write. it is an option available in most BIOS. This shouldnt cause a problem if it isnt enabled but things in general (games for example) should run a little quicker. Simply enter the BIOS when you boot up, search for the option, change it and F10 (usually) is save and exit, machine will reboot. All done.
Acoustic Energy Corinium Speaker Review: A Stunner in Green!
Back
