Pc Gaming on AE100
Discussion in 'Projectors, Screens & Video Processors' started by keelby1, May 20, 2004.
  1. keelby1
    keelby1
    Dec 11, 2002
    1,189
    38
    Grimsby
    +14
    Not sure if this should be in the HCPC section but I'm sure its something simple.
    When playing games I'm only getting a screen ratio of 4.3 with bars on either side on my projector, where as all other programmes display in 16.9. When I use the svideo output through to my tv its in 16.9 my tv.
    Anyone any ideas please
  2. NonPayingMember
    NonPayingMember
    Previously Liam @ Prog AV
    Oct 18, 2002
    8,522
    Kent
    +830
    You need to connect your PC to the projector using a VGA lead rather than s-video (can't quite make out if this is what you have done or not!). You may be able to send a signal out from the PC that will exactly match the AE100's native resolution (858 x 484) by changing the resolution your grpahics card is set to using a piece of software called powerstrip
    http://www.entechtaiwan.com/ps.htm
    Have a read/search around the HCPC forum and you should find plenty more info.
    HTH
  3. Mr.D
    Mr.D
    Jul 14, 2000
    11,180
    +1,226
    A lot of games will set their resolutions independant of the desktop settings. They are also likely to set a 4x3 resolution as such in PC direct mode the ae100 will map the 4x3 resolution into a 4x3 area of the panel.
    The only way you'll likely get 16x9 is if the game runs in a 16x9 resolution and its one that the ae100 can accept.
    getting a 1:1 mapping of the desktop resolution to the panny ( 856x480 on mione I think) is unlikely to improve things as its really dependant on the game.
  4. NonPayingMember
    NonPayingMember
    Oct 18, 2002
    8,522
    Kent
    +830
    I stand corrected :suicide:
    If you haven't tried it yet I would still give powerstrip a go and see what you think of the DVD playback :cool:
  5. Kramer
    Kramer
    There was a list on avs of "widescreen" supporting games but you'll need to do a search as I saw it ages ago. Most games require a registry tweak/hack though.
    The widescreen resolution will usually appear under the games graphics settings but only if the PC already has the new resolution stored.
    Best of luck.
    :smoke:
  6. keelby1
    keelby1
    Dec 11, 2002
    1,189
    38
    Grimsby
    +14
    I'm using a vga connection to the panny-I use the svideo connecton for my tv which works fine
    I thought it may be in the games resolution, but it seems strange that all the other programmes apart from the games work in 16.9
  7. bonzobanana
    bonzobanana
    Aug 21, 2001
    3,449
    Yeovil
    +220
    I generally use 800x600 with my AE100 and I'm very pleased with the results and can get a full screen image. What should I be setting it to for superior results?
