pc game communication
Discussion in 'General Video Gaming Chat' started by zap, Sep 24, 2003.
  1. zap
    zap
    May 19, 2001
    282
    U.K.
    +3
    Does anyone know if there is a way to communicate like xbox live when playing online pc games. I am currently trying Enemy Territory which plays great, but I really miss the chat and banter.
    Is this option restricted to certain games or is there the ability to run some sort of communication software.
    Can anyone recommend any other games that include the ability to comunicate with other players.
  2. UncagedTyphoon
    UncagedTyphoon
    Jun 7, 2003
    653
    City Street having it Large Essex
    +3
    I know a friend on mine plays medal of honour on pc on line
    with headset will look into this for you see what software you need etc
  3. zap
    zap
    May 19, 2001
    282
    U.K.
    +3
    thanks typhoon
  4. UncagedTyphoon
    UncagedTyphoon
    Jun 7, 2003
    653
    +3
    Right ZAP
    The software you need is microsoft game voice
    which is a free download if you goto google and just type in
    game voice you should find it :lesson:
    As for hard ware you will need a head set like the xbox one
    my friend was talking about a hub aswell :confused:
    all new to me hope this helps
    :smashin:
  5. john87
    john87
  6. Kitch
    Kitch
    Apr 18, 2001
    572
    46
    Nr Sheffield
    +191
  7. flibb
    flibb
    ROger wilco is another one, but rely's on base stations. I play dod quiet a bit and this has voice built in, tends to be used more in clan play than on publics. You will need a reasonable sound card as some arnt able to handle using the speakers a mic at the same time, think its called full duplex. Most cards do this apart from dsome real cheap ones, I use a videologic sonicfury, think they are around £30ish, combined with a real cheap headset £10 dixons. I would like to get another mic and use it with my senheisers (sp?).
    All the best
    Flibb
  8. Bondy007
    Bondy007
    Jan 31, 2003
    93
    9
    Sheep Shagging Country
    Stay away from Roger Wilco, it was good but it's been bought by GamesSpy and now apparently contains spyware.
    Comms is not standard on most PC games yet and you have to use 3rd party software such as Ventrillo or Teamspeak (both already mentioned above). There are a couple of FPS games in developement which are offering in-game comms - inspired by the xbox games no doubt
    In the meanwhile comms is mainly used for Clan matches, if you've got a few mates who play the same game you can play together while taunting or helping each other.
    My headphones and microphone unit cost £3 at a computer fair!
