i am thonking of bying a new pc with an amd 3000+ s754. Can you tell me please if this system is good enough for video editing? is there someone using the same processor?
i use an amd 3200xp+ with a gig of ddr memory with a geforce 5900xt and find it more than good enough for me just make sure you have at least a gig of ddr memory and a big hard drive depending what sort of length movie/video you editing.
Well I agree that a 3Ghz processor is more than powerful enough for editing, I only use a P4 1.8Ghz. 1Gb of RAM would make the PC fly when editing, but you could easily get away with 512Mb or even at a push 256Mb (depending on software you use). I would suggest that you get 2 HDDs. The first one should have the OS and all other software and the second should only be used for the capture & editing files. Don't even install the editing software on there. DV footage takes approx 14Gb per hour and then you need more space for editing and file conversion. I always look at every hour of footage I edit will need approx 30Gb of space to make sure I have plenty spare. So make sure you get as a minimum a 120Gb drive as you will soon eat all that space up. Mark.
think 256meg pushing it if it will be used on windows xp as that in itself eats memory but good advice about the seperate hdds.
Well I did say 'at a push' as it will work, just very slowly! It is then only a fairly cheap & simple upgrade when funds allow. My current editing PC was supplied with only 512Mb and was ok, but when I upgraded to 1Gb of RAM it really started to fly when rendering etc. I think unless a large jump in processor is being considered then memory will give the biggest improvement in performance of any upgrade for editing. For this reason I would always recommend spending a little more money and getting 1Gb of RAM and perhaps a slightly lower spec processor if funds are tight. Mark.
I've just made my first DVD on my PC. I have a AMD 2400Mhz processor and 512Mb of RAM (I think, although am not very technically minded and my Dad built the PC). I am running Win2000 and Pinnacle Studio 9 SE. The movie I made was nothign fancy and had about 150 scenes with transitions between each one, and a menu with some sound. Its just over an hour long, but took about 3 hours to render. I'm sure it could have been done much much quicker on a faster machine, but then if you leave it on over night to render you dont know the difference anyway. Dave
