PC DVD re-writer - any help appreciated
Discussion in 'Blu-ray & DVD Players & Recorders' started by Shady, Nov 30, 2004.
  1. Shady
    Shady
    Oct 4, 2001
    1,008
    Sitting at my desk
    +50
    Hi chaps
    I am looking to purchase a DVD re-writer (internal PC), to make copies of our wedding DVD and also to edit together footage taken by Fathers, Uncles etc... in order to produce disks to send out for Christmas.
    However, I am new to all this. What should I be looking for in terms of a DVD writer ? I am used to creating CD's and installing the unit into the PC, but am bewildered by the + / - and dual layer formats. What would be the recommendations ?
    Should I go for a dual layer + / - burner, which seems the obvious choice and if so, what would be the most appropriate media to record onto (I have Nero 6) ? From looking back through previous posts it appears that the - format is more compatible than +.
    Any help would be appreciated (as ever) from those in the know.
  2. PHOBIC ®
    PHOBIC ®
    Oct 19, 2004
    168
    UK
    I use an LG dual -/+ and so far have used rediculously cheap overprints CD blanks to record music, and so far just Datasafe DVD-r to record mpegs. No problems so far
  3. SDHoward
    SDHoward
    Nov 1, 2004
    250
    I also have an lg, it supports everything including ram, and is quite cheap too
  4. laser
    laser
    Aug 1, 2004
    924
    Hartlepool
    +28
    I've been using a Pioneer A05 -r/-rw and a Pioneer A08 -r/-rw/+r/+rw with no problems.
    Picked the A08 for £47.00 at the local computer fair and made the drive multi-region with the firmare available on the Internet. No problems over the last two months and records to all DVD's I've used from the cheapies to the more expensive discs.
