PC DVD player that decodes DTS?
Discussion in 'Desktop & Laptop Computers Forum' started by MartinCo, Apr 4, 2001.
  1. MartinCo
    MartinCo
    Apr 4, 2001
    853
    Liverpool
    <new user de-cloaks!>
    I'm considering going the HCPC route with a projector similar to what quite a few people seem to be doing.
    do any PC DVD software players decode DTS?
    and if so to which soundcards (any with an optical out?)
    thanks
    Martin
  2. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    Newest versions of WinDVD and PowerDVD support passthrough DTS (not decode), not all sound cards are the same and some have compatibility problems. The SB Live 5.1 player is a safe bet. If you really need to decode DTS because your amp doesn't support it then I only know of a Yamaha card that can do it.
  3. Jenz
    Jenz
    The Guillemot Fortissmo is very reliable and cheap at @£35 featuring DD/DTS Passthru with WinDVD and PowerDVD.
    OK for games to, wouldn't spend the extra on the SB if its only for HTPC use.
  4. MartinCo
    MartinCo
    Apr 4, 2001
    853
    Liverpool
    thanks guys...
    I just meant decode (or pass-thru as you put it) going to my dd/dts amp so presumeably any soundcard with a digital out would work.
    do all PC DVD drives have an optical out to connect to the soundcard? (I remember some older Pioneer drives didn't have this).
  5. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    No not all sound cards with digital work. The fortissimo is fine though. The SB is an extra £20 (£55 ish), for that you best games sound card bar non. No other card that I know of can output digital 5.1 for games.
    [ 04-04-2001: Message edited by: Jeff ]
